Old 08-20-2012, 04:20 PM   #14 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by roosterk0031 View Post
I'd say P&G won't, only way P&G is effective is if you cant get 70% or higher engine loading, with your automatic it will probalby down shift at 30-40% if anything close to my 2 GM's. Sentra SE-R did testing with his car with different engine loading using P&G.
http://ecomodder.com/forum/showthrea...d-19594-2.html
With his car 70% load during the pulse, and engine off during coast is need to break even vs constant speed. I'm pretty sure that's impossible with a GM auto you can't get 50% load unless your REV's are way to high to be affective. And you probably won't be going engine off, 09-10 Cobalts auto's do allow flat towing so maybe your's does, but would be a lot of wear on the starter.
With my 02 pontiac i can hold to the engine load steady at just about any load %
"The only real mistake is the one from which we learn nothing."
- Henry Ford
