Old 08-20-2012, 11:57 PM   #427 (permalink)
nnyscolex
so the problem is due to corroded wiring specifically on your ground so if it happens again use you jumper cables from your negative terminal to the block and try starting it again if it starts right up that's your problem
so an easy fix replace the ground wire
The Following User Says Thank You to nnyscolex For This Useful Post:
Sven7 (08-21-2012)
