Old 08-21-2012, 12:51 AM   #1 (permalink)
tjts1
Tire pressure sticker
Was working on a 2002 S40 owned by extended family when I decided to check the tire pressure while the ATF was draining out. Found an interesting tire pressure sticker on this car. I haven't seen one the recomended a different pressure for economy. Is this common? Usually that have a higher pressure for "sustained high speed driving".
I found all 4 tires in the mid 20s. I brought them up to the higher spec.
