Old 08-21-2012, 09:11 PM   #35 (permalink)
2000neon
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
C/R is calculated by BDC cylinder volume over TDC cylinder volume.
It doesn't take throtteling or valve timing into account.
You are correct as far as static compression ratio, but then there is also dynamic compression, which does take the other factors into consideration.
