Originally Posted by 2000neon
That is actually exactly what I had in mind! Great minds think alike Im trying to figure out the best way to lay out the coroplast, and how many sections to do it in. More brainstorming time.
Nice! I'd align the ribs longitudinally so it bends easily, but you probably knew that as well.
If you have a large 4x8 sheet it should pretty much cover the whole thing, right? Otherwise let the split be at the middle because the corners will want to peel themselves back off.
Edit- 1,111th post! Hah
