Old 08-22-2012, 09:45 AM   #36 (permalink)
iveyjh
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
The Safc just adjusts the Map sensor according to the throttle position sensor and rpm's. The ECU will compensate and change A/F ratio back to stoich. I run without O2 sensor in limp mode and then you can add or subtract fuel without the ecu interfering. It's best to check exhaust temp with EGT sensor. I adjust for light load cruising and there is not much risk at lean light load conditions.
