Old 08-22-2012, 02:17 PM   #3 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I opted to wait until I received the motor to purchase a small sprocket due to lack of specs (shaft size / RPM range). So I hooked it up to my EV boat battery pack (also 48 volts) while in my vise only to have it fly out immediately, this thing has serious 0 RPM power! I re-clamped and continued testing with my "digital" optical tachometer. I got 6570 RPM no load at 48 volts (probably more like 52 volts) and 3240 RPM no load at 24 volts (probably more like 26). From that I guessed that I'd have about 3000 RPM at max load / power.
I also measured the Tire circumference to be 42" and the driven sprocket has 36 teeth.
From there I calculated that with the smallest ANSI 41 sprocket available (6 tooth) I should see 20 mph@ 3000 rpm, faster than desired, but slowest easily available gear ratio.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
