Old 08-22-2012, 02:32 PM   #33 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
2001 Hyundia Tiburon... 2L "betaII" engine, all stock, 4-speed Auto.... Worst ever. $3,500 in repairs=1yr. Both front wheel bearings(Bearing in Hub assembly), Driver side half axle, 2 motor mounts, 1 Trans mount, Break pads/Rotors, Header(Cracked OEM), Alternator, Radiator, Belt, installed Ground Loop Isolator(still had Electrical short somewhere) Headlights would blow above 3000rpms?! Then Head Gasket blew... all around 100k mi
Some cars are just NOT ment to be...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
