Old 08-23-2012, 01:02 PM   #9 (permalink)
Daox
Unfortunately, the 6 speed C series has very short differential gearing (C60 is 4.529:1, C62 is 4.312:1). So, even though you get an extra gear, it doesn't help in on the top end. All the 6th gear ratios I have say they use a .725:1. Almost all the 5 speeds use a .815:1, although some use the .725:1.
The Following User Says Thank You to Daox For This Useful Post:
Chisel (08-24-2012)
