What I am thinking for the hinge is two hinges spaced reasonably far apart at the top of the window. The two problems I see with that is that they will be in the airflow, and since the roof is bubble shaped, and is curved across the top of the rear window. I am afraid that with two hinges spaced apart, they will both be slightly curved different directions and may bind against eachother? Or I could just be overthinking things, this may even be a case where have "sloppy" hinges may be better and allow some wiggle room between them.
