Old 08-23-2012, 10:49 PM   #3 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by Betuaintgotthis View Post
1 - What if the hydrogen generator was independant of the alternator ie solar charging battery in boot and device switched on by relay from ignition or seperate switch. A slow draw of 5 amps should last 8-12 hours depending on the battery installed...
The poster above gave you a good answer. You would be better off using that solar panel to delete your alternator.
2 -If an independant hydrogen generator was fitted that was high amp's ie 100/200amps could this be used as some kind of crude nitro burst?. Battery wont last long but neither would a nitro bottle.
Nitrous-Oxide (Nitro) is an injection of oxygen, not fuel, so hydrogen injection would not be similar. That said, I think interesting things could happen with H2 injection. I'm no chemist, so I have no idea what interesting things that might be.
Flakbadger (08-25-2012)
