Old 08-24-2012, 02:01 PM   #5 (permalink)
serialk11r
Originally Posted by Sven7 View Post
I think you're going to have trouble attaching, detaching and living with the Kammback ("spoiler") unless you want to keep the top up permanently.
Many new convertibles have a vertical mesh fabric sheet behind the headrests that arrests vortexes in the cabin, reducing noise. I've been considering one for the Rabbit but it's not a high priority. Maybe you'd like to pioneer a DIY version?
I studied the way the top folds, and I believe there should be enough space for a permanently attached Kammback spoiler, though there may be space limitations. Nevertheless, I intend to have the top up on any trip that will exceed 35mph, it's just too noisy. There's also the issue of the trunk (engine cover) not being able to open with something sticking out the window, I haven't thought about that though.
I'm not actually a true "roadster guy", I just got the car because I like its lightweight philosophy, and because it's a great driver's car. If I could snag a hardtop one, I would
I do need to play with the streamline template to figure out how far behind the car I want a spoiler to extend. I really hope it's not necessary as the stock visibility out the rear is just so good, but the rear end is really quite short which sucks for aero.
One of the biggest problems I think is the airflow off the side of the cabin, I think there are probably pretty strong trailing vortices. Not sure about how to make an aesthetically pleasing solution to address that...
