Originally Posted by Piwoslaw
Ecomodded, someone here once remarked that kill switches should be of the momentary type, since it is possible to push and forget, especially if something suddenly grabs your attention. I believe there was something about a situation when he needed to bump start fast, but forgot to flip the switch and the engine wouldn't start. Lots of panic but no serious consequences, thankfully.
Just something to keep in mind.
BTW, is your PS pump electric, or is it run off of the engine?
So far i have messed up three times trying to start with the switch in the off position, eventually it will will become routine, which will be nice
My power steering runs off the belt so i get it when in gear, it coast's quite well in 5th gear, i was surprised by that.
