Originally Posted by 2000neon
What I am thinking for the hinge is two hinges spaced reasonably far apart at the top of the window. .
do you have a pick a part locally?
94-95 honda accords have a rear trunk hinges which "articulate" such that you can mount the hinges underneath the kammback and they will lift the kammback up and away. they come complete with gas struts to help you lift and hold the kammback up.
it might be you have glass right where the hinges would go - just trying to think of ideas......
