Old 08-25-2012, 11:36 PM   #2 (permalink)
oil pan 4
Turbos help the fuel economy on diesels.
They do have a bypass for the exhaust, its called a waste gate.
The intake also has a bypass valve, called a blow off valve, its operated by intake vacuum, anything less than about 5''Hg and the blow off valve is open.
Diesels do not require blow off valves.
I intend to use a BOV on my diesel to allow air to by pass the compressor at low speed before the turbo lights off, I measured measured 1''Hg in the intake piping so far, driving it kind of easy.
Other wise turbos help diesels about 90% of the time. You wouldnt want to deactivate it.
