That should be the 2.2L before the Ecotec 2.2, If I'm not too much mistaken. Those poor little things have to work so hard to move a heavy brick like those redesigned s-10s. Your truck is a few hundred pounds heavier than mine. For an experiment, you could try one tank of gas not using 5th gear at all. How many miles on your truck? I forgot to mention that with both of mine, and in fact every car I buy, I use a can of RESTORE, you can find it at wal-mart. Are you on any of the s10 forums?
