Old 08-26-2012, 10:56 PM   #20 (permalink)
oil pan 4
If you are going to lean burn I think you will want to avoid 15.7 to 16:1 air fuel ratio.
I believe that to be the exhaust valve burning a/f ratio, at least if you use it under heavy load.
18:1 is safe.
