Old 08-27-2012, 04:11 AM   #40 (permalink)
stillsearching
Never mind then. I thought I'd heard of a 6-cycle engine that went intake-compression-power-compression-purge-exhaust. I didn't know about the steam, would that be on the 5th stroke?
Personally I don't think water should be allowed anywhere near an engine (it's corrosive); but if this would allow deleting the radiator, hoses, pumps and anti-freeze (which is poisonous to puppies and kittens) it might be worth it.
Yup 5th stroke, as I think I mentioned up above.
It's possible that stainless steel exhaust and valves would be needed, and maybe a more corrosion resistant aluminum block and heads, but I don't see how that's intolerable. Iron engines would probably work fine for testing.
