Well, Ah did a bit of photoshop, and she will get even uglier with these mods.
No tail in the pic yet, but it's a beginning idea of what I could possibly do. I'd probably skin it in galvanized sheet metal with adding curves at the corners to make it a little more slippery. But because of how bad the body is already, it would probably make more sense to just start over from scratch.
Maybe I'd be better off to just find an airstream to replace the whole body including front end. And then make a better tail.
The main reason I'm thinking of keeping this is that its out of smog, so a diesel swap would be easy, with just about any diesel I'd like and could fit.
I guess lower height is better for cd right? Like what should be the max running height I should shoot for if making a new body?
I'd be into making a pop up sleeper, but yeah, has to be hard top similar to either the a frame trailer, or that one you showed on the hot dog van.
