Old 08-28-2012, 06:09 AM   #11 (permalink)
BennyL
German Hypermiler
Originally Posted by mcrews View Post
You need to define 'smaller'
What you mean is narrower. Smaller means smaller diameter.
Smaller would prove for worse mileage.
Narrower would provide such a small gain that I would not concider the lose of handling and comfort.
Have you aired up the tires to 40-45psi?
Sorry, my fault. I meant narrower tires, with same diameter.
Both tires are stock recommended sizes. 175/80R14 is the narrowest regular size for this car, 195/65R15 is the most sold tire in germany, and also stock recommended. In size 175 there are only an few different tires to buy, but in 195/65R15 there are about 300 different profiles and a lot of LRR-tires to buy.
In the moment i´m driving very bad all-weather tires from the last owner of my car. So i need to buy some new tires and rims for summer.
I´ll drive the tires at maximum sidewall pressure, but actually the mounted tires are so bad, i wont try it with them...
Kind regards
Benny
ecomodding in germany, with prices of more than 8$ per gallon....
