One thing you might really want to consider is fabricating a hinge to make the door open up suicide style. The car/motorcycle will probably be low to the ground (should be due to how weight transfers side to side) so I bet it would be way easier to get out with a suicide door. Wouldn't have to twist around in what could be a tight fit in the cabin.
Max Trenkle
Student Engineer - TTU Motorsports
