Originally Posted by mcrews
good luck
Based on some of your other posts... not sure if being serious or being a dick.
Either way, Shorter trips I can definitely reduce the speed because it's not as time sensitive..
Originally Posted by MetroMPG
Dropping from 70 to 65 mph will result in a noticeable difference in MPG. Missing a fuel stop is gravy.
I also agree with mcrews about instrumentation: it's worth it to get a MPG display. A ScanGauge or equivalent is also useful since it reports coolant temperature (and saves your "max" value) - perfect for developing a partial grille block.
I'll have to look into that. Thanks to both of you guys (and for all the other information on this site).
