Old 08-29-2012, 09:20 AM   #21 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
If you can get a T-56 cheap I'd recommend doing it.
As you said, a number of people have swapped manuals into Panthers. It ain't easy but Mustang master/slave cylinder kits help a lot.
The T-56 will tolerate massive torque - they are common in Corvettes, vipers, and performance Mustangs. This massive torque rating translates into a very, very reliable transmission for a low-power ecomodder, and as an ecomodder you can get away with a very light clutch. Also they are available with a truly massive overdrive top gear - either 0.67:1 or 0.5:1. Lower engine speed at a given road speed equals lower air flow and engine frictional losses. Mucho efficiency.
I would beware of engine-off coasting with an automatic. With the engine off, you are getting no tranny fluid flow through the cooler.
This project is so right. I didn't know that vintage of Panther had such a good Cd.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
