Old 08-29-2012, 05:16 PM   #28 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Well, the scientist in me got tickled after reading this article.
Yesterday, I disconnected the fuel injector harness and spark plug wires from the 2 center cylinders on my Saturn SL1. It starts, it idles (a little rougher than stock but not bad), it sounds like a wussy version of a v-twin. How does it drive?
After driving it around a parking lot, i didn't think it would have enough power to maintain highway speeds. I was wrong. Besides the fact that it takes about 15-20 seconds to get up to 55mph, it actually holds 55mph on the flats in 5th gear at about 3-5mmHG on the vacuum gauge. Taking hills is quite scary, and i find that i have to downshift way sooner and use much higher rpms to limit the amount of speed lost.
I suspect the A/F ratio is really rich right now, given that air is passing through the center two cylinders without fuel, which is probably causing lean readings from the 02 sensor and dumping tons of fuel into the 2 operating cylinders. I'm sure my MPG is taking a hit overall, but it's fun to experiment!
The car stock with a brand new motor has 100hp and 114ftlb. Right now (182,000miles), the car probably has a 10% hit in performance due to wear. Given the experiences I'm having with this current half engine, and plugging numbers into the Aero+RR calculator on this site, I'd say the torque output is somewhere around 35ftlb or so at the wheels.
So this got me thinking about getting rid of the stock engine and transmission and installing a motorcycle engine that meets those requirements. Some sources say the Saturn Sl1 SOHC engine weighs about 200lbs, and the MP2 transmission is probably about the same. I'm thinking a 800cc +/- in single or v-twin configuration would suffice. I'd also save about 200 lbs.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
