Old 08-29-2012, 07:15 PM   #200 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Czesc RRC,
Flow Illustrator is not something to "Test" a design with, it is intended to be used to illustrate what flow might look like --->> If you already know what it looks like! <<---
In other words, you adjust the settings until the flow looks like it should. It is really nothing more than a toy, it is designed to provide a short movie illustrating approximately what you think the fluid (air or liquid) is doing as it passes over a 2d object.
It is fun to play with and helps to gain an understanding of how the different variables affect flow.
So 100 is simply just a number bigger than 90 and smaller than 110, it really does not represent any particular speed in the real world.
I hope this helps you understand this a little better.
BTW, Moja Zona jest Polka. z Wroclawia.
