Thanks, it should be level- whatever.
Picked up about 8 sq ft of coroplast from the dumpster at work today. Yayy
Also went to the junk yard and pulled the headlight buckets from a '79 Cadillac. $10. Bringin' a touch of class to this shizz!
Got halfway through pulling some tail light plugs at the yard and realized they're all just spade connectors. I'll buy some spare connectors after work and just splice them in. No wires cut yet!
Once the lights are hooked up I can start laying out the angles in real life to get the boat tail frame started. If the angles and Photoshop are right it should be overall shorter than I'd anticipated
For sure with the size of the lights (just as tall as the license plate) it is theoretically possible to have a wake of about two square feet.
So tired physically, mentally and emotionally right now. I need to keep myself busy to avoid thinking about certain things.
