Old 08-30-2012, 09:02 AM   #64 (permalink)
pete c
I suspect your gain is the result of adjusting the nut behind the wheel which is without a doubt the best mod ever mentioned on this board.
The fact that you are on this board suggests that it has happened. I question the increased periods between servicing. Are you refering to air filter maintenance? Perhaps that service period is extended, but, it is an extremely easy maintenance, so I doubt there is any sort of cost benefit.
As for the effect on other maintenance, I can't imagine it would help any. It could hurt as low restriction air filters may let more crap past meaning engine wear could increase and your oil could get dirty quicker.
The Following User Says Thank You to pete c For This Useful Post:
t vago (08-30-2012)
