Thanks Oilpan, every little bit helps right. I remember reading, dont try to remove 100 lbs from one place, remove 1 lb from 100 places. I think that was from a drag racing mag but the concept is valid.
This sub is more worktruck than anything, man windows, locks, rubber floors, front and rear bench seats, no 3rd row, no rear heat or ac
My focus is not on weight reduction so much as the celica is. Aero will be the focus as it will be most effective. A bellypan too as I can actually climb under the rig without it on jackstands.
