Old 08-30-2012, 01:21 PM   #2 (permalink)
Bart
Have you found a truck yet? I'm looking to get rid of an F350, 89', FrankenFord, everything works but not well. The engine and trans run great and have always passed inspection in NJ. It needs cat back exhaust (cat is fairly new). It also needs a front drive shaft and the radiator leaks so the air conditioner will over heat the truck if used to long. It has a 460ci motor and gets 9 mpg (down hill with a tailwind). There is a tow hitch with brake control and various balls and pintle hook.
