Ok, I did some photoshop to the template I found here.
This is a rough draft, I might still need to go slightly taller in the front, but I'm not sure yet.
The first shot is the RV as of now.
Then the first attempt at remaking it using the template.
The tail piece I showed would be only used while driving, then folded up for parking.
I was wondering if the bottom part could just be replaced with flat side skirts like semi's have, angled towards the rear wheels instead of doing a belly pan (might be a real pain for this... )
Anyways, am I screwed here, or does this look like something that could net some serious gains, along with motor diy (electric fan, electronic ignition, and electric fuel pump)
