Here is the video of my
motor spinning!
From my blog...
I finally got the manual transmission fluid in and put the wheels back on the car. Once that was done, it was time for a 12 volt motor spin test.
Well right off the bat the coupling + flywheel were wobbling! The coupling didn't quite make it onto the taper locking part on the shaft and the pressure plate actually would hit part of the transmission!
Now here I was dreading what I thought I had to do next: take everything out and start over!
But instead I decided to try something else, I loosened the two coupling bolts then tried using a screwdriver as a wedge to get the coupling more centered. It worked better, but still not great. Then my dad had the idea of running the system on 12 volts and using the wicked strong clutch to force the coupling center and it worked! The flywheel looks correct, no more clicking sounds and the transmission no longer vibrates!
