Old 08-31-2012, 05:30 AM   #41 (permalink)
oil pan 4
Originally Posted by Sporty Modder View Post
The engine feels very healthy when it is in closed loop mode (cold) once it warms up and goes into open loop it develops the misfire right off idle until I get some rpms, and only after sitting at a light for a while, then it clears up and runs great.
It sounds like a fuel problem. It does not sound like a ignition problem.
That has to be a sensor or sensor wiring or sensor connector problem.
Since it only does it in closed loop and it kind of clears up after running for a while in closed loop.
In open loop it should be running off the TPS, IAT and oxygen sensor.
In closed loop it adds Coolant temperature, knock, MAF.
If it was an EGT problem or leak it would happen all the time, if the EGR was stuck open all the time during closed loop it would likely stall.
An ignition problem would likely be worse on cold start up.
Do you have a scangauge?
If not you may want to get one.
Originally Posted by Varn View Post
If you haven't done it put on new spark plugs and plug wires. You might want to check out the engine compression. Seems like I remember that some of the older GM v8s had trouble with cam wear although I may be thinking older models.
That reminds me, if you have a flat tappet lifter engine, do not use SM rated gasoline engine oil.
replacing the clogged cats.
You should have just gutted them if you can get away with it there.
Correction:
I said "so is the second row", I ment that they weighted close to 100 pounds not that they were in mint condition. The 2nd row seats are in the back yard now and my dog sleeps on them untill I set them on fire and turn them in for scrap.
Sportymodder:
Where are all the attaching points for your roof rack?
I may pick one up some time and keep it in the garage for they 90% of the time when I wouldn't need it.
Untill then I will likely be populating the roof with more solar panels so I need to avoid putting them near roof rack attaching points.
Its goint to get to the point where I will have to have a roof rack if I want to put anything on the roof due to the solar.
