Old 08-31-2012, 09:02 AM   #4 (permalink)
NeilBlanchard
Lowering a car reduces the frontal area by a tiny amount. If your tires are 7" wide, then lowering it an inch reduces the frontal area by a whopping 14 square inches, or less than a 1/10th of a square foot (0.0972 sq ft to be precise).
A typical car has a frontal area of say 22 sq ft and has a Cd of about 0.33. That means the CdA is 7.26 sq ft. If you reduce the Cd to 0.32, then you reduce the CdA to 7.04 sq ft -- which is more than 2X the reduction you would get by lowering the car 1".
You can probably easily achieve a Cd of 0.30 or better by doing a couple of the simpler ecomods; like grill blocks, smooth wheel covers, rear wheel skirts -- let alone Kamm backs, belly pans, and boattails.
The Following 4 Users Say Thank You to NeilBlanchard For This Useful Post:
AntiochOG (11-23-2013), mcrews (08-31-2012), UltArc (09-01-2012), War_Wagon (08-31-2012)
