Old 09-02-2012, 06:53 PM   #2 (permalink)
amcpacer
Indeed it appears that it always meters propane to the engine while it is running. I think it would be best to coast in neutral and use the brakes. That way the engine will be turning at idle speeds and will ingest less air / fuel mix as opposed to a higher rpm deceleration in gear.
