Old 09-03-2012, 12:10 AM   #4 (permalink)
JellyBeanDriver
JellyBeanDriver's Avatar
Originally Posted by SmellyCat View Post
so I have this 15 watt solar panel. . It's cranking out 23 x
Volts. Will this cook my 12 volt battery? Sc
Solar panels are current limited. Though the open circuit voltage is very high, it won't ever see it when connected to your battery.
No, it won't overcharge your battery. The amperage that panel can put out is just over an amp as the other person said, and only at the brightest part of the day with the sun overhead. Put it inside your car and it will be even less with the window attenuating the sun.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
