Originally Posted by MTrenk
Those open sides mean that you're creating a huge low pressure area on the front behind your addition, and air is certainly rushing into that low pressure area. I would recommend covering the whole front of the car with that shape, and making it all closed off.
What about the the blinkers (if it isn't clear from the picture, they are under the bumper). Can you think of a solution that doesn't require a compound curve in transparent plastic, or 5 different components? Probably the easiest thing to do is to move them to the bullnose - but even that is too much.
"Brutally simple" is a key requirement for this one, although I may well make a more sophisticated bullnose for the Civic.
Thanks
