Old 09-04-2012, 07:04 PM   #17 (permalink)
aerohead
sweet spot
I've read there is a sweet spot for ground clearance; lowering typically improves aero but there is a point at which further lowering starts to make the aero worse again.
Thanks Frank.If you should happen to run across that one again,it would be a good one for us to chew on.
