Hi Metro,
Try it. You can always take it off. If you hear less noise at high speed from the A pillar, and upper third of the front window, its probably working.
I was thinking about uses 3m Dual Lock I had left over from relocating the I-PASS transponder into my car a few years ago. At least until edbso had his good result. Here is a link to the Dual Lock
http://www.andybaird.com/travels/gertie/superlock.htm .
Take a look at this if you missed edbso's stuff:
http://ecomodder.com/forum/showthrea...rs-1209-2.html
