Old 09-05-2012, 08:02 PM   #1 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Efficiency/Reliability of Small Light engines
Sooo... maybe theres a thread or two somewhere about this. Motorcycle/scooters is helpful in that particular category, but i haven't found too much discussion about "regular" 1-2 cylinder gas/diesel engines. Like those that one would use for a Go-cart or (Horizontal shaft) Mowers, and industrial work machines, to use for various projects.
Has anyone done a project from a relatively puney "5HP=196cc Briggs&Stratton" or a larger/similar type engine here?
One thing i do know, is that maintenence is a consistant chore, and the Carburators suck and are utterly poor performers. But what if you were to replace them with better Carbs used from small displacement scooters/motorcycles for better tuning of engine power and fuel performance??
Where would be a good place to purchase these Engines alone? Anyone know of credible/cheap online sources?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
