Well, my truck weighs 4000 lbs and has at least as much frontal area as your Volvo..... But I have 2 WD, 5 spd manual, and a 2.8L 4 cyl engine.
You might start with stuff that doesn't cost much - DWL, DWB, grille block, tire pressure, front end alignment, and rear end alignment if your car has IRS. Your 15% to 20% goal is conservative.
What RPM is your engine at 55 or 60 MPH?
