When you get down that low, try cycling the ignition off and on a few times before bump-starting. It takes more than the standard 3 seconds to get the fuel pressure up. Do a really fast off-on, wait for everything to click, do it again, and then again. If you do this on a quiet morning you can actually hear the fuel pump's tone change once the pressure is up. It sounds like the difference between an automatic idling in N and then in D.
![](http://ecomodder.com/forum/fe-graphs/sig268a.png)
