Old 09-06-2012, 01:22 PM   #25 (permalink)
jamesqf
Originally Posted by ecomodded View Post
Because you are injecting a larger amount of fuel with more losses to heat, friction and the force of the rapid acceleration.
But you are doing that for a proportionately shorter length of time, so - assuming your engine &c is equally efficient at all loads & RPMs - you should wind up using exactly the same amount of fuel.
