Old 09-06-2012, 07:31 PM   #34 (permalink)
aerohead
28-degrees
Originally Posted by CigaR007 View Post
That is what I want to find out as this will be a trial and error type of experiment. I am religiously following Mitsubishi's take on VGs.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Given that Mitsubishi and Renault have undertaken that strategy, I am certain it has merit, if properly applied. That is where the challenge resides imo.
Try and stay away from any spoiler which produces anything close to a 28-degree angle when measured projecting up and forward,grazing the backlight or it's header.
This 28-degree angle has been found to create flow which is be extremely unstable.The wake behind the Echo will jump between a square-back and fastback type wake,playing hell with the drag.
And limit your up-kick angle (if you use it) to no more than 30-degrees.
CAR and DRIVER Magazine investigated spoilers back in the 1970s and found that drag increased when their spoilers exceeded the 30-degree mark.
Good luck!
CigaR007 (09-07-2012)
