Old 09-06-2012, 10:27 PM   #97 (permalink)
bobo333
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Hi guys,
After much reading and researching and looking and checking i think it may have just been a coincidence that it froze up after i put the thermostat in and it was actually caused by a vapor lock from when i replaced the coolant, doesn't explain why there wasn't one in there in the first place though. On that note im gonna try putting it back in and carefully bleeding the coolant to make sure there are no air bubbles.
In other news i pulled the dash facia off the other day to give the wiring a quick tidy up as it had gotten messy from adding in the speakers, amp, thermofans and other bits and bobs... i got a lil carried away though and ended up with the whole loom out again but its much tidier now and everything is almost where it should be:
The wires hanging out on the left are for the HU, wiper switch and heater switch, just need to extend the wiper and heater wires and add a factory style plug in before i tape it all up nice and neat.
Then in the middle (the white plug) is the loom for the guage cluster, all finished, 1 plug to get everything in/out.
On the right is the wiring for the headlights and thermos (the bundle with the green wires in it) same again a factory style plug will be added to the end then all taped up to make servicing the switch panel nice and easy.
Above that are the factory green/white plugs that have all of the wires coming in from the engine bay, and next to them (just out of the pic) is another factory style plug i added to bring in the thermofan wires, the LPG system wires and a couple of spares (spotties?) from the engine bay... and this is where we cross over to the other side of the firewall:
The LPG wiring used to go over the top of the engine then through a hole in the firewall but i wanted all of the wiring running long the same place so i redid it, this loom now contains the LPG wires, the tacho signal, the thermofan signals and 2 spares.
All taped up and run to the appropriate places:
Now all of the wiring comes though the firewall in the same place and i just have 3 plugs to disconnect the engine bay side from the dash side.
Have you considered raising compression? My 66 F100 got right at 20mpg with the 4spd/granny. Mostly this is due to compression. Probably the easier would be decking the head, but I've never dealt with a dual fuel system and not sure about compression and LPG.
Another thought is if you can run a smaller alternator. Not sure what it's running currently, but something smaller might create a bit less pull.
20mpg :O thats amazing! is that with hypermiling? and not on the highway im guessing?
rebuilding the heads is on the cards eventually, i wanna put in hardened valves/seats to help with wear from the LPG so raising the compression might be a goer then too.
it currently has an old school generator still so replacement with an alt will happen soon, it wont be small though as i will be using this as a demo truck for my car audio business, i will have a switch on the alt though so it only charges the 2 big deep cycle batteries i have when it needs to.
I need all of my bed for lugging around MDF so the lower bed cover wont work for me.
I think the vapor lock Or low fill in the radiator makes the most since to me, and I think the heater should have priority (first heat available) and a small flow all the time back to the radiator.Please correct me if Im incorrect
Yeah thats what im thinking too, im going to try putting the thermostat back in today and bleed it properly to make sure there are no air bubbles
Wow epic long post... Thanks for lookin
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
