Old 09-07-2012, 10:06 AM   #36 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Try and stay away from any spoiler which produces anything close to a 28-degree angle when measured projecting up and forward,grazing the backlight or it's header.
This 28-degree angle has been found to create flow which is be extremely unstable.The wake behind the Echo will jump between a square-back and fastback type wake,playing hell with the drag.
And limit your up-kick angle (if you use it) to no more than 30-degrees.
CAR and DRIVER Magazine investigated spoilers back in the 1970s and found that drag increased when their spoilers exceeded the 30-degree mark.
Good luck!
Duly noted ! Many thanks !
