Old 09-07-2012, 09:45 PM   #1 (permalink)
oil pan 4
Super V.E. for diesels
Super Volumemetric Efficiency
I studied this years ago, around 2004. Reason back then was to make gas powered cars go faster. I hadn't thought about it in a long time.
Something reminded me of it and I realized it could be used for fuel economy too, mainly on diesels.
Basicly you get inside your intake runners harmonic range (depending on how long they are) and you stuff up to 10% more air into your cylinders, with no additional parts or moving parts.
With a turbodiesel you have boost. Increased pressure does effect harmonics.
10psi of boost and the heat you would expect from it (after being intercooled) has the effect of making the runners seem like they are about 10% longer. The added heat and pressure slows down the speed at which the intake pulses move.
