Old 09-08-2012, 02:06 PM   #11 (permalink)
oil pan 4
The biggest problem with using super V.E. on diesels is the intake runners will need to be really long to keep the motor a harmonic range at cruise speed.
If you have 24 inch runners and start going up a hill and start pushing 20psi of boost the runners are going to effectivly become 28 inches long. Thats more useful.
If you could stretch them out to 32 inches, with a little boost they could become quite useful for towing/crusing. Use the 4th (+4%) harmonic range for cruise, put your foot down and bring it out of over drive and add more boost to get into the 3rd harmonic range (+7%), and when you drop it into 2nd or 3rd gear going over a mountian pass RPMs and PSI go up and bring you into the 2st harmonic range (+10%).
I am pretty much stuck with my OEM 24 inch runner intake. I dont think I could beat them for towing and power. I dont think I have enough room for the 32'' long runners needed to take advantage of harmonics at cruise RPM.
Maybe some of the 4cylinder guys do.
I like flow harmonics. I'm putting an expansion chamber exhaust on my chainsaw too.
Its kind of hobby.
Also water injection will slow down the pluses, but to what degree I do not know.
