Old 09-10-2012, 03:00 PM   #6 (permalink)
some_other_dave
Going up in wheel diameter is probably the easiest way to do this. It is often hard to find tires with the same width as your original ones that have a very tall "aspect ratio". Much easier to find tires for larger wheels that have a larger overall diameter and fewer revs per mile.
It looks like what you want is a tire that is (3.73 / 3.45) times as big. That's about a 1.08 multiplier. Look up your current tires on a site like tirerack.com and see what the revs-per-mile figure is. Then search around for tires that have a revs-per-mile figure that is about 0.92 (1/1.08) times the current figure.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
hat_man (09-13-2012)
