Old 09-10-2012, 09:48 PM   #32 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by shovel View Post
I'll be curious how the belly pan is tackled to address the live axles, unless you're lowering it & pulling those up.. though a live axle can only allow a little bit of lowering, too due to interference with the uniframe & engine.
There was another guy on here who tried aeromodding the bottom of his cherokee, idk if he ever went through with it or not but the for the front axles he made an air dam to direct the air around. I suppose one could design an air dam for the rear with a slit in in the middle for the shaft
"The only real mistake is the one from which we learn nothing."
- Henry Ford
