Old 09-11-2012, 11:16 AM   #6 (permalink)
WD40
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
The bottom line is that the nuts need to come off.
I have had to use a chisel to split a nut that was stuck before.
You only need to split one side as it will spread easy once its split.
It does work really easy and the end result is you get the nut off.
You just need to try and stay away from the bolt itself, nuts are easily replaced.
The nuts are usually softer material then the bolts.
2000 Insight MT 106K Citrus A/C
